The Notso Special
Questions and answers about the Yamaha FS1
jeroenvans
Bericht door jeroenvans »
PD schreef:whats the sice of you piston?
Flika schreef:Yes it's going to be 48mm bore, tuned YG1 barrel and piston, 22mm carb.......................
Flika
Bericht door Flika »
Spec at the moment is 47mm bore and 21mm carb seems to be working Ok 8)
Bericht door jonnotje »
have you already driven with your tuned fizzy?
Flika
Yes I've been riding it and putting some miles on the clock and have done some re-working to the ports, I've been using a standard cylinder head while the other one was being machined, it came back today. Got to wait another week or two then it's back on the dyno and this time I'll take some video. This time hopefully get the 12hp :shock: Here's a pic of the modified head 8)
looks good 8)
wat topspeed does it have??
(3 years ago since my last englisch lesson:oops : )
woow a very high pressure head :shock:
nice work on that :twisted:
i hope it will work and that it wont run a hole in the piston :P
Flika
Compression is set at 13.5:1 with 0.7mm of squish, hope it works out ok.
Flika
Mission accomplished
<img src="http://img10.imageshack.us/img10/7867/dscf1469m.jpg" width="800">
<img src="http://img10.imageshack.us/img10/8650/dscf1470k.jpg" width="800">
congrats man! :cheers:
(now do it wit 40mm bore :mrgreen:)
miran72
Bericht door miran72 »
Wat is er te feliciteren hier, ik kan die aan die grafiek moeilijk lezen wat nou de prestaties zijn die grafiek staat erop in posterformaat ik denk
60 m/ph
13000 toeren
15 bhp
heb ik datgoed?
klik erop of lees de getalletjes links
looks very good :D
congratulations!!! :D
Flika
miran72 schreef:Wat is er te feliciteren hier, ik kan die aan die grafiek moeilijk lezen wat nou de prestaties zijn die grafiek staat erop in posterformaat ik denk
60 m/ph
13000 toeren
15 bhp
heb ik datgoed?
Those readings are the base settings for the graph
Nice man! :D
Never seen a FS1 with 12bhp, until now 8)
Niels schreef:Nice man! :D
waar staat bhp voor :oops: :P
oh lama, ik lees ergens dat het pk is.. klopt dat?
Flika
I wish I spoke Dutch :?
