Electronic ignition
Geplaatst: 30 dec 2012, 18:03
door funkymoped
Do you guys know anyone who does an electronic ignition kit that fits easily to the FS1E please.
Geplaatst: 30 dec 2012, 18:28
door woers
Geplaatst: 30 dec 2012, 18:50
door funkymoped
I have no lights on my bike they glow very little, My engine is very tuned and the points close up often on long rides so yes it was a question, and also I want to buy a kit that an idiot like me can fit and cant be seen as I dont want any modifications spoiling the look of the bike.
Thank you!
Geplaatst: 30 dec 2012, 19:13
door woers
I have the problem with my lights to ...
Door een cdi of hpi of wat is het verschil te zetten gaat het probleem met de lichtsterkte toch niet opgelost zijn? Ofwel?
Dan moet ik dat ook is gaan kopen!!
Wait for another reaction. I'm not sure.
And nice that you dont want to spoil the looks!
http://www.jmpbonderdelen.nl/hpi-ontste ... a-fs1.html
Geplaatst: 30 dec 2012, 19:22
door pee67
Ever thought of chancing the rectifier?
Geplaatst: 30 dec 2012, 19:31
door funkymoped
I have changed everything
Geplaatst: 30 dec 2012, 19:38
door pee67
okay, was just a question
Geplaatst: 30 dec 2012, 19:54
door funkymoped
There is very little current coming from the yellow wire out of the engine?
Geplaatst: 30 dec 2012, 20:11
door pee67
How little?
And from the green wire?
Geplaatst: 31 dec 2012, 11:10
door funkymoped
I havent tested the green wire as I was told the high voltage comes from the yellow one,
Very little from yellow a glow if you plug a bulb on it!
Geplaatst: 31 dec 2012, 11:17
Sounds like you just need another light coil.
Geplaatst: 31 dec 2012, 16:26
door funkymoped
Thats what i though but a while ago the bike broke down and the wire from the condesor to the points had been worn away by the crankshaft so I changed the whole rotor assembly.
Geplaatst: 31 dec 2012, 19:20
Switch the light coils or fix the insulation from the first ignition.
Geplaatst: 01 jan 2013, 10:18
door funkymoped
I knew you would say that, ok I will do this first and see if there is lights.
